Benkarl
I did download proscan and was able to connect to my PC and control the scanner through the PC. Now I'm in the process of trying to figure out how to program it for my areas (my home and a location I visit frequently).
Good, You are 'getting your feet wet', with Proscan. But, Until you get your scanner replaced. Hold off, on trying to program it with Proscan.I did download proscan and was able to connect to my PC and control the scanner through the PC. Now I'm in the process of trying to figure out how to program it for my areas (my home and a location I visit frequently).
You might want to request that your thread be moved to the Texas Forum. There are several San Antonio members post fairly frequently. One of them might be able to make suggestions. To do that, do not create a new thread. Instead, click on the Report in the lower left corner of one of your posts, and request that a moderator move your thread to the state forum. Someone in the area would be more likely to see it there. You could also be a little more specific on your location, like a fairly nearby street or highway intersection, to get a little more information on where you are in that area.I did buy a premium membership and I've been able to download frequencies into my scanner (the new one). Unfortunately, I'm not actually picking anything up with it except occasional static. The national weather service frequencies work but that's it. I added amateur radio, various public safety channels, corporate channels, etc. I even added Citizen's Band and that's not picking up anything. I'm in a major city with stuff all around me so I would think I'd pick up something. I'm assuming maybe my little handheld scanner doesn't have enough range and I may need a bigger antenna.
While you downloaded the RR database. If you downloaded data that the RR database says, are P25, NXDN, or DMR systems. You will just need to correctly program a P25 talkgroup. Because, The BCD325p2 (obviously)comes with p25 capability. But, To do any NXDN, or DMR systems. You will have to upgrade your scanner by buying the software key for each. That is what I did for my BCD325p2. So I have all three(P25/NXDN/DMR)I did buy a premium membership and I've been able to download frequencies into my scanner (the new one). Unfortunately, I'm not actually picking anything up with it except occasional static. The national weather service frequencies work but that's it. I added amateur radio, various public safety channels, corporate channels, etc. I even added Citizen's Band and that's not picking up anything. I'm in a major city with stuff all around me so I would think I'd pick up something. I'm assuming maybe my little handheld scanner doesn't have enough range and I may need a bigger antenna.
I'm using ProScan. I will try to get this moved but I'm curious if there is a reason to move vs starting a fresh thread?You might want to request that your thread be moved to the Texas Forum. There are several San Antonio members post fairly frequently. One of them might be able to make suggestions. To do that, do not create a new thread. Instead, click on the Report in the lower left corner of one of your posts, and request that a moderator move your thread to the state forum. Someone in the area would be more likely to see it there. You could also be a little more specific on your location, like a fairly nearby street or highway intersection, to get a little more information on where you are in that area.
What software are you using? You could post your programming file, so that someone else can take a look & possibly make suggestions. I'm in Dallas, so all I could give you would be generalized suggestions, as it's been a very long time since I've been to your area.
I programmed with ProScan. I also bought "ProVoice" and "DMR" which has allowed me to pick up some things, but not as much as I think I should be able to. I didn't see anything that said NXDN and ProVoice didn't give me any warnings with any of the frequencies I added to my scanner. It did do that when I was adding DMR without the upgrade.While you downloaded the RR database. If you downloaded data that the RR database says, are P25, NXDN, or DMR systems. You will just need to correctly program a P25 talkgroup. Because, The BCD325p2 (obviously)comes with p25 capability. But, To do any NXDN, or DMR systems. You will have to upgrade your scanner by buying the software key for each. That is what I did for my BCD325p2. So I have all three(P25/NXDN/DMR)
Have you programmed your scanner with ProScan?
Did you import the Bexar/San Antonio system from the database? Be sure that the correct LCN#s are in place. Those are required to monitor an EDACS system.I programmed with ProScan. I also bought "ProVoice" and "DMR" which has allowed me to pick up some things, but not as much as I think I should be able to. I didn't see anything that said NXDN and ProVoice didn't give me any warnings with any of the frequencies I added to my scanner. It did do that when I was adding DMR without the upgrade.
I am using ProVoice. I programmed a bunch of the frequencies on that list by using ProScan to import whatever the default is from RadioReference. The main thing I seem to be picking up is the "System Frequencies" at the start of the list, not the talk groups.I would also note that the majority of public safety agencies (Police/Fire/EMS) for both San Antonio, as well as Bexar County, are on this system:
San Antonio/Bexar County Trunking System, San Antonio, Texas
San Antonio/Bexar County Trunking System Profilewww.radioreference.com
If you look at the various talkgroups for agencies in the county, the Mode column for the talkgroups are usually labeled as D. That signifies that ProVoice is in use. Unless you purchased the ProVoice upgrade, you will not be able to monitor them. Some of them show an M in the Mode column, which means both analog (which you can hear without the upgrade) and ProVoice radio traffic uses that TGID. There are a few encrypted talkgroups used by SAPD; these are tagged with a DE in the mode column. However, dispatch talkgroups are not currently encrypted.
Eventually, San Antonio & Bexar County will will transition to a P25 Phase II trunked system. Some talkgroups can be patched into the newer system, but most activity is on the old EDACS system, and using ProVoice.
A couple of the smaller cities in the county are using the LCRA P25 Phase II system.
Lower Colorado River Authority (LCRA) P25 Trunking System, Various, Texas
Lower Colorado River Authority (LCRA) P25 Trunking System Profilewww.radioreference.com
I imported from the database. I'm assuming that has the correct LCN#s. I'm not sure where to find those if it doesn't as that page doesn't seem to have it.Did you import the Bexar/San Antonio system from the database? Be sure that the correct LCN#s are in place. Those are required to monitor an EDACS system.
Starting a duplicate thread, on the same issue, is against forum rules. While your current thread is not totally "in the wrong place", my thought is that by moving it to the Texas forum, you would be much more likely to get the attention of someone actually in your area.I'm using ProScan. I will try to get this moved but I'm curious if there is a reason to move vs starting a fresh thread?
OK, you lost me there. For a trunked system, when programmed correctly, you would only hear active talkgroups, not the "system frequencies".I am using ProVoice. I programmed a bunch of the frequencies on that list by using ProScan to import whatever the default is from RadioReference. The main thing I seem to be picking up is the "System Frequencies" at the start of the list, not the talk groups.
I did add the LCRA talk group as well.
Ok, I'll request a move.Starting a duplicate thread, on the same issue, is against forum rules. While your current thread is not totally "in the wrong place", my thought is that by moving it to the Texas forum, you would be much more likely to get the attention of someone actually in your area.
I've attached the file. Thanks for all your help, by the way.If you are picking up zero talkgroups, then something is missing from your programming on that system.
Save & post your ProScan file. It's a *.txt file, which is acceptable to attach. (Sentinel and ARC files have to be zipped in order to be attached to a post.)
I'll take a closer look in the morning. But with a quick once-over look, I don't see anything out of place or entered incorrectly.I've attached the file. Thanks for all your help, by the way.
Yes. I upgraded the firmware yesterday before I applied the ProVoice and DMR upgrades. I just checked and confirmed 1.08.01. I just checked the upgrades and I do see that ProVoice is already activated.I'll take a closer look in the morning. But with a quick once-over look, I don't see anything out of place or entered incorrectly.
Just to confirm, when, on the scanner, you use the menu, and scroll down to access Settings
Then, select Upgrade & press Enter
When you try to access the ProVoice upgrade, it should be saying already upgraded. Just a shot in the dark, that maybe it did not activate correctly. And you do have the latest firmware, right?
When you go into the Settings menu, then select "See Scanner Info"
then select Firmware version, you should be seeing 1.08.01
BCD996P2FirmwareUpdate < UnidenMan4 < TWiki
info.uniden.com
OkYes. I upgraded the firmware yesterday before I applied the ProVoice and DMR upgrades. I just checked and confirmed 1.08.01. I just checked the upgrades and I do see that ProVoice is already activated.
