Baofeng Programming BF-F8HP with CHIRP - can only hear NOAA
nd5y
Wichita Falls, TX
Then what CAN I listen to on the handheld if repeaters aren't transmitting. Beside NOAA.
Stuff the Baofeng can receive doesn't transmit continuously 24/7 like commercial broadcast and NOAA weather.
What you can hear depends on your location and other factors.
What good is a ham if in an emergency there's no communication? I would do better with a set of walke-talkies?
Ham radio is useless in an emergency unless you arrange to have at least one competent person available to monitor and respond if you need help. You cannot depend on random people to be willing or smart enough to help you or even to hear your hand held radio at all to begin with. The same is true for GMRS, FRS, MURS and CB.
Marine_Cotporal
Simplex Kid
Dang, the videos never get that far into explanation! They all concentrate on the mechanics of programming & not the functions upon use. Your comments are informative & welcome. I'll definitely take the NOAA off of the index. I have an emergency radio in the go bag so really not as necessary. If the SHTF I wanted some sort of actual communication device.
You don’t have to delete the NOAA frequency. Leave it there. On Chirp just go to the last column and check S for the skip. It will skip that frequency when it scans. You can do that for any frequency.
Coffeecup-OK
I'm working to get my technicians, license so I can be part of the local organization. Once I'm legit I'll try & get within their buddy system. Thank you.
