Programming Cable for XGP radios
AES-256-Encryption
"Be the change we need"
39A71
This is the diagram I found from another user, my question is for the 5V reg is that something that i have to add to the board or is that already on the board? I am waiting for a pile of mics I got cheap to arrive and I was gonna make a few USB TTL program cables. Thanks
Edit I just realized I am silly and the MAX233A is the interface box!
AES-256-Encryption
39A71
The MAX233A is an RS-232 driver/receiver chip. Looks like battery voltage is tapped from the radio mic connector then a separate 5V regulator is used to power the MAX233A.
Yeah I think if I go and follow the pinout of the connector and just use the RED 5v and get a 3.3v for the line. Should work? I think. I am confused as some mics have all the holes for pins and others do not.
prcguy
The MAX233A supply voltage rating is 4.5 to 5.5VDC. Instead of thinking what might work and building something that doesn't, study the data sheets for all the parts your using so it has a chance of working.
AES-256-Encryption
39A71
I see a guy on ebay selling them and a friend of mine opened it up and its a TTL to USB and its wired in there? problem is finding a mic with all the EDC holes available.
prcguy
I would look for a Hirose adapter that has enough pins and holes in the body that allows you to move pins around. I've made a number of keyloading adapters for various radios with those.
AES-256-Encryption
39A71
I was told the OTTO mics some have all pins accessible.
merlin
DN32su
I bought one of forts cables some year or couple back. Had some usage and works perfectly
AES-256-Encryption
39A71
Perfect yeah I just need A cable lol. If I end up making extras ill sell them to break even on costs but I just need A CABLE! lol
