According to GRE's website, the P/N 100-016 USB programming cable that comes with the PSR-500 and others can be used with other Radio Shack scanners. I have a Pro-96 that I'd like to use with the cable but I was under the impression that you need an adapter to take it from a stereo TRS to a mono. Is an adapter actually needed or can you use the cable as is? If an adapter is needed, which pins are needed to build your own or is it possible to use a stereo to mono 1/8" audio adapter for this purpose?
Thanks!
Thanks!
