cherry hill
You might have done something wrong when programming it ? because i can hear cherry hill all the time, they dont use the pro voice too much except on channel 4, you have to make sure when you set the edacs system up when you start it as a wide standard system, then after that right after you put each frequency in, you have to also make sure youre putting in the lcn numbers too, you do that with each frequency right after entering it, if you look in rr you will see the lcn numbers next to the frequencies such as 01 to 05 try all this first and then enter the tgids and see what happens Danny...
