Programming CK and Lambont EMS
crossfire291
C-K, Ontario, Canada
I wiped my scanner about a month ago in order to clean things up a bit. There are a few agencies that I haven't programmed back into the scanner yet.
I am currently trying to program CK and Lambton EMS, but seem to be having a lot of trouble compared to last time I programed them. I also have Toronto Fire on my scanner again and they came in loud and clear on the week end in T.O.
I programmed the freqs, then the TGID's. I found out I displaced a couple number in the TGID's. I now went to correct the mistakes, and am unable to. I first tried to input over the TGID's, and when that didn't work, I deleted them, and tried to enter them fresh. I can't, I get told they are bad TGID's.
Also, I am set up for 800/900 splinter, I think that's what I had last time. Also, what fleetmap should I have? Custom, or preset? Anything else you can think of to help me get back on track would be great!
Forts
Ontario, Canada
Boy I had to read that twice... I thought you said you were getting Toronto Fire in Chatham over the weekend. That would be impressive! Sort of related to that I have UniTrunker logging the new London P25 system (which has a common frequency with one of the Toronto Public Safety sites) and for a few hours it was picking them up and logging them (from Strathroy!). That's a solid 200kms + as the crow flies. I couldn't believe when I saw that.
Anywhoo... If you need any further help with EMS just give me a shout and I'll see if I can help you out again.
crossfire291
Thanks guys.
Forts, I wish it were possible for me to get Toronto Fire from here! Sorry for the confusion as well. I was driving on the 401 to London a few days ago, and a possible structure fire came through in Chatham. I was picking CK Fire up till about Iona Rd. where the signal strength dropped off the map.
exkalibur
York, Ontario
Hey, on the old Toronto Fire UHF system, I used to listen to them daily on my portable some 150km away. I remember Peel Police (VHF) on a portable scanner when the weather was just right too!
crossfire291
I seem to have a terrible time with Fleetnet and my scanner. To re-cap, my scanner is a Uni BC346. Just got it back from having a butt load of repairs done. It's basically refurbished now. I have to get C-K & Lambton EMS back on this thing, and can't seem to get it working.
I need to know what to set my fleetmap as, preset, or custom.
Set Status Bit to "yes", or "Ignor"?
Set End Code, "yes", or "ignor"?
Last time it seems I was told that my band plan should be set to VHF, but I don't see that as an option, just800/900 Standar, 800 Splinter, and Custom.
I'm also going to be in Sarnia on Friday. I've never actually listened to Lambton EMS while in Sarnia, on this scanner. Should I still be able to listen to Lambont EMS on the Wallaceburg site, or should I program 31SARN as well?
Forts
Ontario, Canada
Are you programming with software or by hand? For Fleetnet you will want to create a Motorola Type II system with a custom bandplan:
Lower freq: 141.0150
Upper freq: 143.9850
Step: 15
Offset: 380
If you are going to be in Sarnia proper then I would program in Site 31 as well. You will get EMS on both sites, but obviously have better signal off the Sarnia tower.
crossfire291
Step: 15
Offset: 380
I've done it the exact way that your thread told me to. Nothing. I've been out in C-K this morning, and I'm not even getting bars on for c-k ems. Both control freqs are good.
I remeber doing it the same way last time, and getting it after finding a transposed number, but everything seems in order this time, and should be working.
VE3JSO
sarnia ont
i have sarnia site programmed in and i can't get kent ems on the sarnia tower and i think the closest tower to kent county is just out of range to me
