Flameout00
Not surprisingly, I'm a bit confused about programming these 2 radios. They were in a GR500 repeater setup, with duplexer, R.I.C.K. and all cables
Looking at the current settings and how they are programmed, both are programmed identical. Is that correct? I'm not sure what the RICK actually does and if it wants them programmed that way?
For example, they were programmed for the 462.025 frequency and both radios were set up with the RX at 467.025 and the TX at 462.025
Also, under Package/Pin Configuration they both also show RICK or l2R Rx Should the TX radio say Tx and not Rx? Example: RICK or I2R Tx
