Hopefully someone can help answer some of the questions I have about trunked systems and how to efficiently scan them. I have several trunked systems in my area (Plano, Allen, Wylie, Murphy (PAWM) and Fort Worth Regional Radio System, for instance). Both of them contain multiple "sites" containing multiple frequencies (primary control channels, alternate control channels, and other channels). Here are some questions:
Do talkgroups belong to the individual sites or are talkgroups common and shared across all the various sites?
Do I need to program every site into the scanner to hear all the traffic?
Do I need to program all the frequencies for each site into the scanner (or only the control channels?)? Does it matter which order I enter the frequencies?
I currently have an SDS100 and am trying to figure out how to make it scan trunked systems faster. My old Pro-106 (only good for P25 Phase I not Phase II) had a "multi-site mode" setting which I could set to "off" (finds first usable control channel and then uses it until it is no longer useable), "Roam" (scanner attempts to find the best possible control channel and then ignores the others until the best one is no longer useable), or "Stationary" (scanner uses the first useable control channel). The SDS100 doesn't have these settings so I don't know how it actually decides which control channel to use.
