SDS100/SDS200: Programming differences between the 200 and the 996P2
videobruce
Buffalo NY
I have the 996P2 for a few years now. I only use the "Quick Save" group since I don't have any 'Trunk' groups I'm interested in. I had 30+ years of using the Pro 2006 behind me.
I believe I do have some multipath issues with some services, but it's hard to tell. 95% of my monitoring is analog simplex services and everything is programmed into this one group since it's complicated (for me) to try to add a separate group. I did try one trunk group, but I could never get it to scan with the 'Quick Save' group active.
So my question(s) are; I have read the 200 programs differently than the 996P2 and it's not as easy (according to some reports I have read).
I have used ProScan for my 996P2. Can that be used for the 200? Just what/where are the differences between the two radios AFA programming?? (other than the addition of the SD card)
tvengr
Well Known Member
Baltimore County, MD
The SDS200 can be programmed by downloading directly from the Radio Reference database using ProScan to create favorites lists. You will still need the free Uniden Sentinel software for firmware updates. You can also scan from the built-in national database while traveling. If you use a GPS, the scanner will automatically select the closest frequencies and systems while you move.
videobruce
Buffalo NY
Can't that be done with the 996P2?
It wouldn't be a issue with me as I manually program the selective services, none are trunk. GPS isn't a issue either.
These "Favorites" list, is that similar to old school/analog channel Banks? These "Favorites Lists", they aren't related services are they? Any type of service can be in any "List"?
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
Yes, it can also be done with the 996P2 & every other supported scanner listed on the top-left portion of Proscan's homepage
Go to the system in question's RRDB listing and click on your target site name's hyperlink as shown under "sites and frequencies". Scroll and find the site location map for a visual representation of where the sites on the simulcast cell are located. Pinpoint where you're located on said map. If you're situated between two or more sites on the simulcast cell then simulcast distortion will likely be an issue for you
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
The 200 is probably not going to help with analog reception issues. Simulcast is a digital trunking issue and that's where the SDS series shines.
hiegtx
Mentor
Dallas, TX
If you are comfortable programming your 996P2, which is what Uniden calls a "DMA Scanner", you won't have a lot of trouble with an SDS200, nor any of the other 'database scanners, that Uniden categorizes as the Home Patrol category. Besides the original Home Patrol-1, and it's follow on HP-2, the other 'database' scanners include the x36HP (BCD436HP & BCD536HP) as well as the SDS100 & SDS200.
What your 996P2 calls "groups", the database scanners refer to them as "Departments". Your P2 has a limit of 20 groups per system. That can be a handicap, especially in urban metro areas using a large regional system, or as a agency on a statewide system. For larger cities, there are often separate groups for public safety- one each for law enforcement (police), and one for fire. In some systems, EMS may also be placed in the same group fire, but in other cases, EMS might instead be a separate group. Multiply that by several cities, as well as smaller towns which only have a few talkgroups, but in a group specific to them, you quite often can exceed the group limitation (20). So, you either have to consolidate talkgroups to reduce the total number of groups, or split them into an additional system. That's not an issue with the SDS200 and other database scanners. While your P2 has a limit of 25,000 'channels', the only limitation for the database scanners is that a Favorites list cannot exceed 1 megabyte. That's a huge difference. Plus, if you need more room, you can add one or more additional favorites lists to handle them. For your P2, you have ten quick keys (0 through 9) to assign to groups. If you have more than ten groups in a system, either the same QK will need to be shared on one or more systems, or else you can have groups without a quick key, In the SDS and x36HP database scanners, you have 100 quick key numbers available (0 through 99) for use, making it simpler to toggle one or more Departments, within a system, on or off while scanning.(Note the the HP-1 & HP-2 do not have quick keys, but you still have no set limit on your number of Departments.)
Your P2 has one programming file. Everything has to fit in there. That can be a handicap when programming for a trip to multiple areas. You'd need to either use a GPS to limit the scanner to systems in the immediate range, or use start-up keys to break your file down to systems in the various areas you'll travel to or through. For the SDS200 and other HP scanners, you can have multiple Favorites lists, say one for your home area, and additional lists for other sections of your trip or the final destination. You can select which lists to be scanned either through the scanner menu, or assign quick keys to them to control when they will be in use.
Note that, since you have already used ProScan for programming your 996P2, ProScan can import your 996P2 file & convert it to a Favorites list for your potential SDS200.
hiegtx
Mentor
Dallas, TX
You have the option to use lists as you would banks, turning them on or off (for scanning) by assigning individual quick keys to them. As Enforcer has noted, a Favorites list can be assigned to a specific purpose (say, for aircraft or marine channels), or any combination of channels and services of interest to you. Other than the one megabyte size limit on individual favorites lists, there is no hard limit on how many Favorites can be loaded to the scanner's SD card. You have 100 quick keys (0 through 99) to be assigned to lists. Note that a given quick key can only be assigned to a single list, so you could not assign #1 to two lists. (If you did, when the lists are loaded to the scanner via Uniden's Sentinel software, or ProScan (or ARC536), the second list would be loaded without any quick key assignment.)
Chris0516
Pittsboro, North Carolina
Before I got Proscan. Along with my BCD436HP then SDS100. I was using Freescan with my BCD325p2. I first bought Proscan. Programming my BCD325p2 was still a bear to program. Not the fault of the software. Just for me, I found my BCD436HP n' SDS100 far easier to program. I had originally been hearing, that. The SDS100 would be harder to program.
