Also, note..... The most common problem people have. You start programming on channel x01, not x00 of whatever bank you are using. EDACS uses Logical Channel Numbers and MUST be put in in the order listed and starting on the correct numbered channel. You can NOT program in LCN 01 thru 05 on scanner channels 111 thru 115 or even 100 thru 104. They would have to be on 101 thru 105.
