while scouting out a place I will be visiting I noticed they have a talkgroup listed as "0-23-456" how would you enter this by hand? I would use sentinel but havent had much luck thanks for any help
Assuming you have the system programmed and you're just missing that one talkgroup, go to Programming Departments, then Channel Options, then Entering ID's if you need to. The format is " To enter a LTR ID, enter the Area Code (0 or 1), enter the Home Repeater Number (01-20), then the User ID (1-254) and press E/yes. Example: 001134. "
You can simply append the Dollywood system from the main database in Sentinel instead of manually entering it. Note that in looking at the system in the database, I did not see a talkgroup matching "0-23-456".
