I'm not in front of my scanner but you turn them on under national systems if using the full database. Otherwise, they should be under each state, after you select a county, where it says "Nationwide" "Statewide" or "County". Look under Nationwide. That is if you're using Sentinel, I don't do much programming on my scanner directly.
