kc2kth
I'm wondering if anyone has tried to group channels for multiple systems and if so how that can be accomplished without duplicating systems (presumably impacting scan speed). Here's my example.
I'm in NJ. The trunked systems I monitor - portions of them at least - are the NJSP, NJICS and Ocean County systems. I also monitor quite a few simplex systems including Ocean County, Toms River and others. I've always simply selected these in Sentinel and added each to it's own FL.
I created an additional FL called "medevac". The intent was to easily select this to monitor the local, county and state medevac channels without monitoring all of the TGs in each system. In all there are probably a half dozen medevac TG/frequencies in all across multiple systems including NJICS, NJSP, Ocean County trunked, and a few simplex. By doing this I have duplicated the trunked systems. I've done something similar to break up county fire from EMS since I tend to listen to fire, but not EMS as much.
After reading through some of the threads here on using quick keys to accomplish some of what I today use FL for I'm rethinking how I do things. With my programming as is, I've never had a need for quick keys. However I've also never been happy with scan speed and I'm thinking duplicating systems had some impact on that.
So the question is if I program each system once, is there a way with quick keys to group channels from multiple systems? Since QK are tied to the system (the same QK can be used for different systems) I don't see a way to accomplish this.
