hgivens
I am fairly new to programming and need some help.
I’m currently having trouble upgrading my Motorola XTL 2500 radio using ASTRO 25 CPS. After successfully getting the radio into bootloader mode, I attempted to perform a flash upgrade. However, I ran into several errors, including "Failed to open the port", "Open Radio Failed" (Error Context: 25, Status: c0000343), and "Failed to download bootcode". I’ve double-checked the USB connection and confirmed that the correct flashcode and FLASHkey are being used, but communication still fails. I’ve also tried power cycling the radio and using different USB ports and cables, but the problem persists. Is anyone familiar with these errors or have any suggestions on troubleshooting this issue?
The flashcode I need to upgrade to upgrade to is 509008-000480-1. The original code plug says the radio is at 409008-002000-1. I have a new code plug file with the new flashcode. I basically did a read on this code plug from the old radio and I am trying to write it into a new one I got. I tried to use the clone wizard with no luck. Then I tried to flash the radio and also got some errors. I have a good code plug it just trying to write this to the radio. I also have a flash key so I know that should not be the problem. I attached a few snips of the errors I am getting.
If anyone have some ideas I am all ears. I could really use the help.
Thanks,
Hunter
Contact info:
hgives06@gmail.com
text 618-554-6265
Thanks,
Hunter
Contact info:
hgives06@gmail.com
text 618-554-6265
