Programming Help on PRO-164
Bucko
Marietta, Ohio
I don't have a 164 but it should be close the same as my old Pro97 and should monitor that system fine being it is analog. A easy to read manual for the 97 is found here Easier to Read Pro-97/2055 Scanner Manual which should be some help. Also software would make it a lot easier for you like Win97 and a 20-047 USB cable. As for Addison only then just enter the Talk Groups for Addison only and Close that system bank, in Open mode you would pick all the TG's.
