programming help
emtmike
I just picked up a 1250 and have a question. Remember I am new to this so be kind. Where do I put PL Tones? And is it on the Tx or Rx?
rustyjw
It is under transmit and receive
Sent from my SM-G920V using Tapatalk
rustyjw
What are you trying to look up? The HELP file is actually very helpful.
emtmike
The help feature of the software is not working for some reason. I programmed 9 channels into the conventional personality section and did a right to radio and only the 1st one programmed into the radio. I dont know how to program different zones ether.
rustyjw
If you open up ZONE in the radio tree, the ZONE window will pop up. The first tab is the zone name. If you haven't added any zones it'll probably say ZONE 1. The next tab are the channels assigned to the zone.
There is probably only 1 channel in the zone, which is why you only see 1 channel after you write the radio. Right click on the first row and select ADD TO END. This will add more rows, aka more channels to the zone.
rustyjw
Under the channel column you can select which channels from a personality you want in the radio, and which channel on the radio it will be assigned ro.
