Programming HT1250
Shillman996
Bergen County, New Jersey
Hi I'm programming an ht1250 with a USB cable profilic driver. When I read or write to the radio the radio goes into test mode, and I get an error saying cps couldn't open the com port.
cifd64
Northern Passaic County, NJ
Make sure the proper COM Port is selected. This can be done by opening the File Drop Down Menu, selecting Read Radio and check to see that the proper com port is available. Depending on your computer, the COM Port will show up as USB or COM 1-48.
If that doesn't work, i can walk you through identifying exactly which port is being utilized for the cable.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Thread moved to Motorola forum as the HT1250 is not a scanner.
cifd64
Thanks Mike, did not see where it was posted. Uninstall the driver then reinstall. If you are positive that the selected comm port is correct, the issue is either the cable, the driver or your computer. What version windows are you using.
cifd64
Shill, do a search on this topic. I know there were some minor issues with SP2 and the USB cable. While the fix was relatively simple, I suggest using a RIB and cable for this.
