Programming HT1550 with Red Battery
dfkwcwp
Does the radio automatically unlock the keypad to program the radio when you clip on the red battery?
Can you enable MDC signalling from the FPP?
NavyBOFH
Where idiots grow on trees
IIRC, the FPP on that model will allow programming of frequencies and associated settings. I think changing things like MDC still requires a computer with CPS since it wasn't deemed necessary for "field programming" since most of the time the MDC ID won't change.
KG4INW
Midlothian, VA
FPP still has to be setup with CPS first. NavyBOFH is correct in that you can only edit certain channel info. Most parameters are still set with CPS.
