programming issues with a tk3170
chief3030
I am having trouble programming a page channel on a tk3170 so that the squelch cancel will close in a preset time period? This has run my head into the ground.
Theroofable
Can you explain what you are trying to do in more detail? What is the effect you want and what do you want it to do for you?
chief3030
I am trying to set up a channel to page only with a certain frequency. Once the page is received I am trying to get the channel to open up where I can hear the transmission. Once that information is received I need the channel to close the squelch so I don't hear any further traffic from that channel or frequency.
Thanks For any help.
ramal121
Lots and lots of watts
Calif Whine Country
Under your two-tone decode window (1,2,or 3, whichever ones you use) set a time in seconds for the auto reset and then make sure "monitor" is checked. After decode the radio will monitor the channel. When the timer expires, monitor is defeated and goes silent again.
