- Joined
- Feb 13, 2021
- Messages
- 3
Hi, I have a Kenwood TH-F7 and I'm trying to get the MCP-F6/F7 ( downloaded from Kenwood ) to work but keep getting " communication timeout error "
My computer is a HP Z400 running Windows 7. ( I also have windows 10 loaded on it but haven't tried that )
I have two interface cables, one is a home made RS232 serial box and the other is a Baofeng USB interface cable. Both exhibit the same error.
As the computer has no built in serial port I have to use a USB to serial port adapter for the serial box. Both adapters show up as " Prolific USB to serial Comm Port " in the Device Manager.
I have an old PC running Windows XP that has a built in serial port and I can use the MCP-F6/F7 software on that with the RS232 box with no problems so I assume the box is working fine.
I can use the USB cable to program my Quansheng radio and it works fine. The other thing is I can use this cable with CHIRP software and it reads from the TH-F7 perfectly, so I'm assuming the COMM port settings are correct and the radio settings are also correct.
I have downloaded and reinstalled the MCP-F6/F7 software. I have tried various sequences of powering the radio on, starting the software and connecting the radio.
It's not the end of the world but it is a pain having to fire up the old PC whenever I want to change the programming.
Any ideas or suggestions much appreciated.
Thanks.
Dave.
Thanks.
Dave.
