Programming Los Angeles County EDACS?
mosocal
I've been trying to program my Pro-95 for L.A. County EDACS system. The RR freq database lists system A, B, and C. The channels for each system start over at 01. Does each system go into a separate bank? There is only one control channel indicated, and it is in system B. At first I put it all into one bank, but it didn't work. I then entered just the B system because it had a contol channel listed, and it had the most frequencies. Now I occasionally pick up some full conversations and some partial ones. Can someone tell me how to program the whole system?
mdfillipp
Orange County CA
each of the systems ("A", "B", or C") must be programmed into individual banks. each freq must be programmed in the order listed in the database, IOW each must be programmed into the channel specified ie for system A, 866.0625 must be programmed into the first channel of the bank, 866.4375 into the second, 867.9375 into the sixth, and so on. Same goes for B and C.
I'd be more specific about programming the Pro-95 itself but I don't own one.
BANDIT
Gainesville, Ga
The first channel number in a Pro95 is 00. Do not program your first frequency LCN1 in this channel.
Start off with channel 1.... 01 as the first channel.
Example: LCN1 goes into channel 01.
LCN2 goes into channel 02.
:D
mosocal
Thanks for your help! So far my best success has been using the trunking freqs from the RS Police Call book. But i'm still not getting everything. I am going to see what I can find usng the 2 scanner method I read about on the forums.
BANDIT
Gainesville, Ga
Check the RR Database here on this site. It should be more up to date than anyting you will find anywhere. On the main page the columns on the left of the page RR Database. :D
