programming P25 correct (Miami Dade)
Sunny Isles Beach, Florida
I am trying to get my bcd396xt programmed correct to monitor Miami Dade´s new P25 Harris system - I have set it up as a p25 system - my question - is it std. trunk where you put in all the frequencies - or only the control channels? and what about base/offset?
I hope someone here can tell me how to set this correct up
Also - I have found another control ch in N. Miami Beach area - 854.5125 also with sid 0065h01
n4yek
Cosby, Tennessee
Deriving my comment on this system: http://www.radioreference.com/apps/db/?sid=7073
You should only use the Control Channels and don't worry about the base/offset, the data stream from the control channel will contain that information and the 396XT will store those automatically.
On a local P25 system, the only thing I entered was the control channels and the scanner picked up and stored them. But, I have a friend who has a Radio Shack Pro 106 (aka GRE 500) and he had to manually enter his offsets. That scanner didn't automatically store them, as well as anyone else around who had that scanner.
Thanks - it works great - the sound is much better in a true p25 system - than it is in systems in mixed mode like hollywood or Broward uses.
240871
i have aproblem... The signal here in N. Miami Beach area seems to be too strong - I have put on the att now - it helped a little - the sound is distored -what else can i do?
JANFINE
MIRAMAR, FL
Dade Co P25 TRS
The signal is not too stong.
The distortion is how it sounds on some channels.
Hopefully they will be adjusting that.
