SlyFerret
Hi all!
I turned on my scanner (PRO-106) last night to find that I could no longer receive the Delaware County (COIRS) system.
I suspected that they might have made some changes, so I sat down tonight to investigate. I found out that the system had rebanded.
I updated my control channels based on the new information in the RR database. Although that fixed the first problem, my radio doesn't seem to be finding the voice channels properly. It locks onto a talkgroup, but I get no audio on the channel. I noticed that the voice frequency that it tunes to is not listed on the system info page in the RR DB, leading me to believe that I'm still dealing with rebanding issues.
The way I understand it, based on this wiki page, P25 systems are supposed to decode the trunk tables from the control channel data rather than from a trunking table stored in the radio. Is that incorrect?
I did try to load the rebanded trunk tables using the ARC500 software, but that didn't seem to fix the problem either. That didn't surprise me too much, as I think that the trunk tables are only for Motorola type II systems. I'm a little stumped.
Is there something different that I need to do to configure the rebanding on a P25 system?
In another thread, somebody stated that they used the following information to reprogram their Undien scanner for the system.
"Their band plan is Position 0, Frequency 851.00625, Spacing 6.250."
How does this translate into the ARC500 user interface to program my PRO-106? I have a feeling that there is some screen in ARC500 that I have yet to find.
Thanks in advance for any help you might be able to offer!
-SF
-SF
