Programming pro97
durgin
I need help programming a motorola II system. The system is the mayo clinic in rochester minnesota. And i have a pro97. Also all the frequencies are in the database under minnesota, olmsted county.
KE5BCP
Analog Man
Lewisville, Texas
Are you doing this manually or with Win97?
You'll need to enter the control frequencies (red and blue), setting each one to MOT.
You will also need to set that particular Bank to MOT.
If you choose to program in talkgroup IDs, you can set the bank to "Closed" mode (a "-" appears under the Bank number while scanning) and receive only the ones that you have programmed in. If you run the bank in "Open" mode (a "+" appears under the Bank number while scanning) then you will receive all talkgroups as transmissions occur on them.
durgin
Thank you W5JSS, i got it figured out. I had all the control frequencies in the FM mode. Now if i could only figure out all the other systems.
