Programming problem with P7100
ROOFLIFECO
Denver
Ok, so I'm not sure what I did here, but I sure hope it's fixable!
I took the personality from a 700P system model, read it from the radio, changed the radio type to "P7100 Scan", changed the groups with "Provoice" from the 700P to "Analog" to program into the P7100.
Now, it shows up with all of the systems programmed in the radio, but the only group that I am able to use at all is Ch. 1 in the first system. If I try to change to a different system, it says "INV SYS" on the screen.
I looked in the feature string in the radio and now it says:
SYSGRP# - 0
TRKSYS# - 255
So basically it is saying now that it will monitor 255 trucked systems, but 0 (well, 1) group?
Is there any way to fix this?
Radioman96p71
Polk County, IA
its saying that you have the capacity to have 255 Trunked Systems, but NO System Groups. Long story short, it means the radio is not set up for EDACS. Conventional only operation.
You could get the feature added from harris, unsure what the cost would be for that.
ROOFLIFECO
Denver
I have an EDACS provoice channel programmed in there and it works just fine...I can hear traffic on it. It just won't let me switch channels at all...
Radioman96p71
Polk County, IA
It could very well be a glitch in the way it handles features. I have exceeded the number of SYSGRP and the radio will work fine if you rearrange things a bit in the personality, but will give fits when you cross the line.
ROOFLIFECO
Denver
Is it option 8 that it has to have for EDACS operation? It says emergency operation, but I'm not sure if thats the same thing or not. I know 29 is provoice...
