Programming PTT Side Tone and 2-Line Display on Icom CS-F70/F1700 software
APD242
Allendale, NJ
Hello All! I am in the process of programming my new Icom F80DT by using Icom software CS-F70/F1700 version 1.2
I cannot figure out how to program a PTT side tone or a two-line display. Any help would be greatly appreciated. Thanks!
Mike
radionerd13669
Useless Contributor
Northern,New York
For the Pre Tone you need to go to the MDC Menu and the pttid- You will see a box labeled RTT Beep. Enable that. You may need to adjust the timer also.
For Two Line display go to the Common menu.
Then go to Key set and display and select two line display. In two line display it just show the channel number above your text.
