Programming question . MURS
xeonman13
Hello.
I began a search last week looking for radios more powerful than GMRS / FRS.
Someone recommended MURS to be which appear to be covered by some radios that I came accross.
Motorola RDX RDV2020. GOt them at a great price (3 of them).
These are out of the box. How can I program them to be on MURS frequencies?
I know about the cable but where can i Get the software?
Local vendor wants 40 each to program.
Should I expect decent range out of these?
What other options do I have besides MURS? I actually was given 5 UHF radios but you need an FCC license. Called the FCC and they said its gotta be for business use.
Any adivce?
b7spectra
EMS Dispatcher
Cobb County, GA
$40 each is a bit steep. $25 is more reasonable. You would have to buy the CPS software from Motorola (or, and this will bring on the SAPS, you can find it on the internet) and purchase a cable to program it with.
If you are going to use them on MURS channels, and the radio's are 2 watts max, I really don't think you should have much problem talking on them. The radio's are 2 channel, so if one channel is busy, just switch to Ch 2. There are probably thousands of unlicensed MURS out there, and with the FCC being so spread out and thin in the investigation department, you won't have much problem.
The RDV2020 is actually a VHF radio. The RDU2020 is the UHF version.
Now, it's time for the SAPS to join in.
rescuecomm
Travelers Rest, SC
SAPS?? Do you mean the radio police?
Incidently, on the Motorola site, it said the CPS for this radio was available as a free down load. The older Motorola Spirit business radios had preprogrammed channels. I suspect this one does too and the CPS just selects from those.
Bob
Avery93
AL
Yep, you can download it for free straight from Motorola, oddly enough. And yes it only lets you select between the pre-programmed frequencies (of which MURS is conspicuously absent), you have to take it to a dealer to have anything else programmed.
K
kb0nly
Guest
MURS is a good option... More power, more range.. Some areas it can be pretty crowded. Around here the MURS channels still has licensed users grandfathered in on it, and since they are licensed they can run more power, etc.. Hard to use a channel when its that active with higher power users.
Any channel that is free, since there is only five to work with, usually has nothing but kiddies on it with the cheap MURS radio they got from Radio Shack.
auxscan
Brooklyn, NY
Im trying to understand why someone would choose a MURS frequency than a GMRS frequency. MURS is on VHF its a license free on the five frequencies but it is limited to 2 watts thats it, GMRS is on UHF a licensed band with 5 watts allowed and 50 watts allowed on a repeater operation..
UHF perform better in metro areas they go through walls better than VHF thats why most public safety in the USA use the UHF band like chicago PD, old Detroit PD, NYPD etc.
clanusb
Northern CA
VHF is good for foliage. Plants like to eat UHF signals a lot quicker than VHF. All depends on what your doing.
Thunderknight
Bletchley Park
Because GMRS requires a license for each non-family individual using it. MURS does not require any license.
For a family, GMRS might be better. For a group of non-related people, GMRS can get expensive.
hockeyshrink
Hey auxscan,
I think it really all depends upon the entirety of factors to be taken into consideration...application (what are you doing on the radio), equipment, terrain, distance needs, as well as operators.
A while back I did some simplex testing from my home setup with mobiles and HTs...MURS (VHF) totally outperformed GMRS (UHF) in this suburban environment. BUT, when you put a repeater in the equation, there is no comparison, assuming the UHF HT can hit the repeater.
In my experience, UHF does work somewhat better in an urban built environment, but as noted by clanusb, foliage in terrain does gobble UHF, making lower freqs preferable in the burbs and beyond. Urban police and fire are using UHF, and CHP still uses VHF low band in the hills. It all depends on how you size up those factors, IMHO.
K
kb0nly
Guest
GMRS around here is as useless as FRS. With all the big box stores selling FRS/GMRS radios and everybody using the GMRS channels without getting licensed anyway its a friggin zoo on those frequencies.
Avery93
AL
I agree with the VHF propagation in rural areas and the bubble packs ruining GMRS. One thing not pointed out is MURS is all but dead in many areas. I have been all through central Alabama and north east Mississippi and outside of the metro areas, haven't heard a thing except for Walmart on channel 4. This leaves you with basically your own set of frequencies without any interference.
I also like being able to monitor other VHF frequencies (receive only) with my MURS HT.
auxscan
Brooklyn, NY
wow didnt think I would get this many replies to my comment lol, I agree with most of you that MURS would be a better service for short range commuincations. Since MURS is vacant compared to the 3 battery radios on GMRS. But if you want a good source of communication get your GMRs license get a commercial UHF radio and if you can set up a repeater. I believe by FCC rules legal on portable radio 5 watts although ive seen some sabers that put out 6 watts. I think and i may be wrong 15 watts for mobile/base operation and 50 watts allowed on GMRS repeater operation. And its all about elevation.
Posted from my iPhone
