Programming Question - Sorta Newbie
mrtizzom
Davison, MI
Hey everyone. Our county recently switched to 800 paging with G4's. I have ours working but wanna make sure that i'm 100% doing things correctly. When it comes to the Control Channels...I have entered our primary and alt control channels. Do I still need to do a full spectrum scan or can it run from just the 2 control channels?? Here is the system we are on:
https://www.radioreference.com/apps/db/?siteId=10238
I have currently the 2 control channels and it full spectrum scan from 851-854. Any advice anyone can give me would be awesome. Thanks in advance for helping out a somewhat newbie.
tglendye
Blue Ridge Mountains, Shenandoah River- VA
You should be safe with just the primary and alternate(s), however I think a lot of people recommend to program all channels. Just in case the system changes and some of the voice channels rotate to control channels. So it maybe an overkill, but I would probably put the other 14 in as well.
Edit: I just saw that you are using Unication G4's- didn't pick up what forum this is in, either. I don't think that would change my mind, unless there are drawbacks using all the frequencies with Unications.
IAmSixNine
Dallas, TX
Motorola systems are pretty good about being reliable on the primary and alternate control channels.
However i only see 1 alternate. Usually there are 2-4 alternates.
Keep that in mind if the system ever has issues and your pager goes out of range as the system might got to a control channel you dont have programmed.
Harris systems i am told are ones that can use any channel as a control channel.
troymail
Silent Key
Given what I see of the system and based on the WACN, I recommend one of these two options:
  • enter all of the site frequencies
  • spectrum scan 851-854
Make sure you've entered the correct WACN, SysID, RFSS and Site values - particularly if using Full Spectrum Scan.
