APX Programming Radio Frequencies
ryolsen8
BEE07
When using the APX CPS Software, where in the Codeplug Configuration menu do l program different radio frequencies?
It would actually be under Conventional Configuration, assuming you're programming conventional and not trunking... Zone Channel Assignment is where you'd go after you program your frequencies, and assign each frequency to a knob position and zone.
KE4ZNR
Radio Geek
Mostly correct: Conventional Configuration->Conventional Personality. You program the actual frequencies into Conventional Personalities which you then assign to the desired Zone/Channel.
