Programming ?'s on a BCD996xt
Pvtqueball
Pine Bluff, Arkansas
Ok I have my Scanner Programed but I have a cpl of ?'s
1. What does the SO mean right above the Grp?
2. I have my Grps Programed but how do I Program the SO?
3. I need a Better Antenna b/c I live out in the Country Any Suggestion?
4. I have alot of the feqs programed by color but they dont Work all the time and Suggestions?
wise871
Florida
S0 means Systems. It will show S0 for systems 1-9 and S1 for 10-19. What program are you using to program the radio?
kilowa22
Oregon
1. S0: Helps Identifies the system being scanned
S0:1234567 90
with the 8 blinking means that system 8 is being scanned. To access a system
press Hold > Press .No > Press keys 0-9 > Select then last number in the system.
To access System with quick key 24 press Hold > .No > 2 > 4
2. Go to the system and Press Func key then the menu button. Use the scroll knob to navigate the menu's. TIP You can navigate to a System by pressing Hold > Func & turn the Scroll knob to reach that system.
3. If you can put one outside a discone antenna is best. Scanner Antennas
4. Don't have any experince with Color settings, but they are set in the menu in the Group, TGID or CNV channel.
UPMan
In Memoriam
Arlington, TX
In kilowa22's answer #1, do not press Hold. The scanner must be scanning for SQK's to function.
