Programming SDS 100 with sentinel
dwayne0564
Xenia, Ohio
Hello, Can I use the same saved configurations done with my Sentinel Software that I used on my 436hp, for my new SDS 100
tvengr
Well Known Member
Baltimore County, MD
Yes! The same favorites lists are used for the x36 and SDS scanners. You need the latest version of Sentinel for the SDS100. Under the Tools tab, you select the Target Model of the scanner you are using which provides the settings for that specific scanner.
jonwienke
More Info Coming Soon!
VA
If you still have the 436, save a copy of your profile, and change the target model of the copy to SDS100. Favorite lists are the same regardless of profile but you want to keep the model-specific settings for each scanner separate.
nessnet
What month is it?
Note that on the 100, you can highly customize the display - and the basic display has different options than your 436.
Once you change the target model, go to edit profile and check your display options.
Also, check out edit display, where the customizations are.
tvengr
Well Known Member
If you want to do a custom setup of the display on your SDS100, under the Edit tab on Sentinel, the Edit Display option is available only if the Target Model is set to SDS100 or SDS200.
