My county is in the process of combining five former Smart Net systems into a Smart Zone system. (Broward County, Florida). So I decided to reprogram both my BCD996T's to take advantage of the multiple site feature that this scanner has.
The way it's set up now, only a select few talkgroups can "roam" to other sites. The problem is this: If I want to hold on one particular talkgroup, you have to know which one of the five sites it's likely to come up on, because apparently the scanner does not check all of the sites on one system for activity on the talkgroup, it only checks the one site that you happen to be holding on. That is, unless I set up something wrong. This would seem to defeat the whole purpose of being able to program multiple sites under a single system.
Did I set up something wrong, or is this the way this scanner operates with multiple sites? I gave all sites under the system the same Quick Key.
