programming the Ingham Co. System
scannerman5000
Eaton Rapids, Michigan
Rob,
how do you have the Ingham Co. System programmed into your radio? I have the entire system programmed into my 396, and it will not properly scan it.
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
I know that you need the LCNs in proper sequence, in order for the scanner to track it properly. Once that has been determined then you can follow all of the regular transmissions on the system.
73's
Ron
rdale
Lansing, MI
It's still EDACS wide for now, it won't be narrow until operational.
rdale
Lansing, MI
That _w_ould be the problem ;>
