Programming the Uniden 325P2
ArizonaHeat
Scottsdale, AZ
I am a total newbie to trunking and have a Uniden Bearcat BCD325P2 on order which I understand is a "Bear" to program.
It looks like FreeScan might be the way to go.
Is there an available database here that can be loaded via FreeScan for SVRCS?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Normally you could purchase a subscription and download it from our database, but I didn't see any Arizona trunk system with that abbreviation - I could have missed it, not knowing the state- but likely your next best bet is to go over to our Arizona forum and ask for a FreeScan file for it. Be specific; other software utilizes a different format.
Is that a system of conventional freqs? ... Anyhow...
In addition, here's an article from our wiki (links are always in blue) that will give you a starting point for understanding how to work with this DMA based scanner. Note that the Easier to Read manuals are all linked at the bottom of...
https://wiki.radioreference.com/index.php/Program_your_DMA_Scanner
Mike
ArizonaHeat
Scottsdale, AZ
325P Programming with FreeScan
I downloaded FreeScan for the 325, and after some convoluted (creative?) work on my laptop I was able to install the Uniden driver...(not the usual way I have installed drivers before!).
Long story short I was able to load a trunked system and got it working.
The only issue I have is that some of the (digital) transmissions are a bit hard to understand as they are garbled (but not encrypted). I played with the Threshold (was on Auto) and it seems to help.
Comments?
Thanks,
Pete
milcom_chaser
Comments?
Thanks,
Pete
If it's a simulcast system, then the garbled audio is par for the course. A true LSM capable radio/pager or scanner is what will alleviate that issue. Uniden is soon (relative term), about to release a scanner which can demodulate LSM. Huge thread about it, with links to videos of it decoding a number of simulcast systems.
Go over to the Arizona forum page, and post your questions, as there are a number of users in PHX...
iMONITOR
Silent Key
S.E. Michigan
I guess I'm just lucky. I have a 996XT, 996P2, and as if today a 325P2, all monitoring Macomb County, MI 9-site P25 simulcast system perfectly! It uses CQPSK aka LSM as some like to call it. I guess I'm just in a good location.
