programming tk-385
rideblue193
Hey guys.
just acquired a tk-385 and i cannot for the life of me figure out how to program this thing!
in the programming software kpd-62d it calls for the network and frequency files. anyone know where to get these or make new ones?
thanks in advance
ramal121
Lots and lots of watts
Calif Whine Country
The TK-385 is a MPT trunking radio. I really doubt you are trying to set it up for a trunked system as these are very uncommon in the US. You should be able to put in conventional frequencies though. You will have to make the zone as conventional.
I have no experience with the 385, but with a 380 you can go to the model pull down and make the radio a conventional only.
Don't worry about the network stuff as this is for trunking only.
cabletech
Puget Sound
Be sure you read the current radio information first so you have data base to work with, other wise you will not be able to do any thing.
rideblue193
Thanks for the reply. I am trying to get trunked frequencies plugged in. My work uses a trunked system and id like to use my own radio. If i try and go to conventional mode it says "network file not found".
dfirefly
Castle Rock, Colorado
hey.... any updates on this topic???
i procured tk-885-1 and looking for these files.... network file in particular.. so i can read from radio and have files to manipulate to get it programmed ...
