wyldman
I am trying to set up the Toronto public safety system.I have all the info,and have set it up as four systems (N,S,E,W) which correspond to the different towers.I hear lots of traffic when searching for ID's,and several of the same TGID's seem to be used on different towers.I have not had a chance to listen long enough to see if all TGID's are sent over all of the towers.Seem to be getting everything,just need to get it cleaned up and organized,and my TGID's entered so I can use the ID scan mode instead.
Here is my problem.My scanner (BC246T) is almost full,and i need to keep my systems as lean as possible so I can fit everything in.So here are my questions.Can I program in the control channels only for this style system ? if yes,can I put jut the all of the different control channels for all 4 towers all together in one system,and then all of the different TGID's into groups in that one system ? or do I need to program each tower separately,with individual TGID's for each tower ? How do i know which TGID's are associated with each tower without days of searching ? How do I know what area of the city use which tower ?I could enter all of the TGID's for the entire city under each individual system (tower),but this is duplicating things like 4 times.
I would like to have it set up just as one system if possible to save space.I have all of Peel Region set up this way,and it works well,but they only use one set of control channels running off of repeaters,not different control channels running off of 4 different towers.
BTW,when I do get this set up,I can share the files if anyone in the Toronto area is interested.I also have good setups for Peel Region (Police and Fire),Pearson Airport,York Region,and some conventional stuff too.
