Programming VHF Astro Spectra
gjhamilton
Hello all this is my first time programming an Astro series radio and I am having some problems. I bought a VHF Astro spectra from Ebay that was supposed to do P25. Read the flashcode and this was not the case. The seller then decided to send me a Vocon only. Replaced the Vocon and now the flashcode is showing P25 operation. However when I read the radio in CPS i am poking around looking for anything P25 related. I cannot find anywhere to enter NAC codes etc. There is not even a tab for P25 in any of the menus. Now since this is my first experience with an Astro Radio I have no idea if the radio is indeed set up for what I need. All that I am trying to do is program some frequencies with NAC codes for receive only. Thanks for the replies in advance.
Tulsa
If the Id tag doesn't have "2.5 KHz stamped on it, then you will need to find a later revision RF board to be able to do the 2.5 steps. I have a Spectra high power that was an early version and I found a mid power with a later RF board swapped the boards and now the high power does 2.5 steps, not a problem for the mid power, I use that for ham only.
