Programming VX-3000 channel groups. Please help!!!
jhutch62
Harrison, Michigan
Ok, after figuring out how to adapt my Motorola ribless cable to work with the Vertex VX-3000, I am now, once again, scratching my head...and it's not so much as it is programming the frequencies in as it is getting access to them once I'm done. I guess I was naive in thinking that like the GM300, this radio would access each programmed frequency just by scrolling the up and down buttons right off the bat... and I'm not even sure if these radios are capable of working like that but I could be wrong. I'm certainly no stranger when it comes to doing this sort of thing, as I am an amateur radio operator and have programmed four or five dozen mobile transceivers for my local Ares, Emergency Management group but they were mostly of the Motorola persuasion. Luckily, our group acquired several dozen of these radios after the narrow banding mandate, which was more due to my county's decision to switch over to digital MPSCS. I know by now it's impossible to make a long story short, so I will get to the point, the radio that I'm currently working on is a 48 channel VHF model, which has 4 operable channel groups of 12, I want to leave groups 0 and 1 in tact because some of the frequencies are still in use...and program groups 2 and 3 but after I download them to the radio, I can only access the "Switch on channel group" and none of the other groups. I've tried every combination of user and dealer settings that are available to me, I think? Below are some screen-shots of the program, so if you know of a clear and concise way to get these radios to access all the channels by merely using the up and down buttons, please let me know.
Thanks,
Jack
chief21
Western NC (Summer); Tampa Bay FL (Winter)
I used to own a VX-3000. If I remember correctly, one of the front panel buttons needs to be programmed as a GROUP(ZONE) UP/DOWN button and another needs to be programmed as a CHANNEL UP/DOWN button in order to move between groups. You'll probably also need a button programmed for scan function.
Check your front panel button programming. The HELP menu may also be useful.
John
In the Western US Mountains :)
I just bought one of these radios from a friend it's supposed to be here in a few days, but I was wondering did you have to use your Motorola rib box or did you just modify the Motorola cable to work I'm just trying to think of what I need to do to program mine now? I was thinking of just buying a cable off of eBay
