Maybe it is not Win96. I went to RS and asked the guy for the software they sell to make the scanner work with the Radio Reference Database. He gave me a square clear package with what appears to be a USB cord in it. I said this is the software and he said yes. It was $35.
The USB cable now sells for $34.97 and comes with a CD. This is NOT "software" to program the scanner, it is JUST THE CABLE required to do so.
The only software I've known RS to have which programs scanners is ScanCat(Lite). It is the WORSE SOFTWARE EVER CREATED TO DO THE JOB. Avoid it like the Swine Flu!
A lot of people think that they can install some programming software and it will lead them in to programming their scanner. It won't. You need to understand the basics of your scanner in order to program it correctly to meet your needs. The PRO-106 is one of the most complex scanners available today. It is not something you should expect to learn "overnight". Some "techies" take days or weeks to learn these things, that's how complex they are.
My suggestion for software is WIN500. But that's because I've used WIN92, WIN93, WIN95 & WIN97. I have used other software as well to program Uniden made scanners, but nothing has matched in ease of use. Then again, these programs were "easy" for me because I learned the scanner first.
Take your time and do as much reading as you can. Don't expect to grasp everything at once. Actually how much you need to know right away depends largely on what system you want to monitor. If you are only monitoring conventional channels, it will be the easiest. If you need to monitor a digital trunked system or two, that will be more difficult. Good luck.
