Programming Wouxun from keypad
brownalan
Northwest Louisiana
I have a UV2D and a UV3D which I've programmed via the USB cable and software. I was away from home and wanted to change the PL tone on one of the programmed memories.
However, I could not get the Wouxun to accept and save the change. Anyone else experience this?
Specifically, I can not change the Menu 15 or Menu 16 items and get the change to stick.
N4KVE
PALM BEACH, FLORIDA
While I am not familiar with how to program that particular radio, I have had that problem on other radios. You can't change the PL in memory. The trick is to transfer the contents of that memory into a VFO, then change the PL, & then save the new info back into the memory. Hope this does it for you. GARY N4KVE
Titan2
I ran into the same problem with my UVD1P. Do a search for Wouxun Dealer Operation. It allowed me to make the changes on mine. Hopefully it will work on the UV2D & UV3D.
