Project 25 Motorola X2-TDMA Questions!
OK, so I have some questions about Project 25 Motorola X2-TDMA.
1. Will this be mandatory eventually to replace the FDMA?
2. Is this an all digital system? (Meaning it doesn't allow analog at all)
3. Does this apply to conventional systems too?
(If you don't have anything nice to say, don't say anything at all)
-Lisa Lynn Smith
mikey60
Oakland County Michigan
1. No, and those that do choose TDMA in the future will probably opt for the P25 Phase II standard over the X-2 format.
2. Yes, 100% digital.
3. I'm sure there are ways it could be used on conventional similar to MotoTRBO. In fact, from what I understand, X-2 is similar in many ways to MotoTRBO.
Mike
mikewazowski
Staff member
Central Ontario
No.
Yes, all digital. All Project25 systems whether FDMA, X2 or Phase II are digital only.
No. At this point X2 is only offered for trunking.
ampulman
South Jersey
I thought I read (here) that if an affiliated unit is unable to connect via TDMA, the site will revert back to FDMA.
Not sure if this applied to both Phase II and X-2.
Amp
mikey60
Amp
That depends on how the talkgroup is set up. Some can be locked to be TDMA only, other can revert to FDMA if needed...
And this is true for both Phase II and X2.
Mike
