project 25
home121
Florida
Seminole county fl. went to project 25, ive set up all the right things. My question is project 25 phase 1 is it nfm or just fm, reason I ask is im getting a good signal s-5 but it is garbled , and does the data decode rate make a difference mine is set to low 75 and high 95 ? using psr 800
bailly2
They are garbled because they are using LSM simulcasting. Highly recommend you get a yagi for
850 MHz, point it at one of the towers, maybe turn up the squelch. Or just turn on the attenuator
For all the frequencies for that system with the antenna you have now
