Project budget entry level repeater system
armour07
Hi I am "planning" to build my budget repeater system.
Here is my list of materials
2 pcs Baofeng BF-F8+ for TX/RX with battery eliminator
1 pc Diamond X50 Antenna
1 pc regulated PSU 12V/10A
1 pc 30W Duplexer / Repeater
I am on a tight budget
Please free to comment and give advise
baltimorecs
Baltimore, MD
I was goig to do the same but then picked up two GR-1225 repeaters, one with duplexer for $325 and one without for $250. Because I use them at work too I already have the software and cables to program too.
zz0468
Banned
What's the actual budget? What's the purpose of the repeater? What frequency? What are you using as a controller? Where will it be deployed?
Without defining goals for a repeater, it's difficult to go back and say whether it was successful or not. That said, using a pair of Baofeng portable radios for the transmitter and receiver of a repeater is a recipe for failure.
teufler
ST PETERS, MISSOURI
BAOFENG SAYS THAT WILL WORK. For how long, that is a question that all of us want to know. Thinking quality and dureablity by the price, most of us have reservations that radios that cost so little will hold up. I have yaesus, kenwoods, and Baofengs. I have had no problems with the Baofengs, they have held up, easy to program and inexpensive compared to other radios.. If thje "experiment fails, the componets will be useable again. I don't see a controller, something that id's and switchs the radios from transmit to receive. Baofeng has those starting at $24.00. I am not sure they have an id'er. The radios should hold up though the transmit radio will be going for longer periods of time as compared to an individual using the radio. If you are going with a vertical antenna separation, you don't needf a cavity, but a single antenna, you will need a cavity. I would think $300 or higher for a set of cavities. Then you will have coax. Todays prices an investiment in copper. I expect a Baofengaccountant will some day run to the head office and say, "we are missing a decimal place, the radio should cost this much"..
chekoz77
South Daytona
Yup it will work. There are a few youtube vids of people doing it. One radio recieves and the other retransmit on the offset. All you need is the 3.5 to 2.5 cable. You can even do it without the cable but audio wouldnt be as good.
WB4CS
Northern Alabama
Yeah it will work.... until the finals are burnt out of the handheld radio that transmits. Handheld radios are not designed for the amount of duty cycle that a repeater has, unless it's barely used. Plus the limited power output of the handheld will not get a whole lot of range, unless you're going for short range anyway.
What about station ID? Not sure if this is for Amateur Radio or some other kind of use, but the "repeater" needs to have a way to ID itself with a legal call sign.
It will work in theory and be a good experiment, but don't expect this thing to be a permanent repeater with a large coverage area.
