I'm planning on permanently mounting a Slim-Jim copper antenna on a mast to the side of an un-used chimney on my house, the height of the mast and material of the mast is yet to be decided. This will be for a local railroad feed. I want to do this right the first time, I've read a lot on here and I'm somewhat confused on how best to do this for this particular setup.
On my ATCS server setup at another location which consists of a KP-20 antenna at the peak of a metal shop I used a Polyphaser in line with the coax which connects to an 8 gauge copper wire and that connects to an 8ft ground rod.
This is the Polyphaser surge protector that I used.
https://www.solidsignal.com/pview.a...K9bY86riuly7TW-4qaKvYM-fjvclyu8xoC3BYQAvD_BwE
Will this setup work also for this antenna and setup?
Do I also need to attach the ground to the antenna itself? I've read that can help with static buildup.
Thanks for your help.
