I agree with this post the most.
Each airport page needs only that airports approach and departure control listed.
A radius of 15 miles for the approach/departure control and 5-7 miles for the airport it self (for when aircraft is on final or transitioning through).
Doing anthing more than that is overkill. If one freq is approaches from the east, then the description or alpha tag is sufficient. Geotagging based on an area only to the east is a bit much.
Maybe I was confused. I was thinking we were talking about having a single complete NORCAL page (as a working Class B/C example) that we link to from the individual airports. Or we break up NORCAL for the approach that is used at a specific airport.
My preference is that we do both. Do you think having both is overkill? Or are we just going to have the specific NORCAL frequencies in use listed in the airport pages?
My other question is how do you propose we define the distances? I know you've specified them in this post, but what is the source of your data?
My preference is that we go back to the FAA data (even if it transitions through Wikipedia, for accessibility/readability), and use their definitions for a Tower, Class B and Class C airspaces.
Here is a readable reference:
FAA National Airspace System Power Point Presentation
Or the base ppt:
http://www.usarmyaviation.com/study...uments/Airspace&download=Airspace Class 1.ppt
If you look at the Terminal Area chart:
SkyVector: Flight Planning / Aeronautical Charts
...it says to contact NORCAL (Class B) App within 20nm
20nm = 23.015589 statute miles
Here is a map of Fresno Air Terminal, it is a Class C airport:
...it has a smaller radius.
Here is the FAA pub:
http://www.faa.gov/air_traffic/publications/atpubs/aim/Chap3/aim0302.html
3-2-4. Class C Airspace
a. Definition. Generally, that airspace from the surface to 4,000 feet above the airport elevation (charted in MSL) surrounding those airports that have an operational control tower, are serviced by a radar approach control, and that have a certain number of IFR operations or passenger enplanements. Although the configuration of each Class C airspace area is individually tailored, the airspace usually consists of a 5 NM radius core surface area that extends from the surface up to 4,000 feet above the airport elevation, and a 10 NM radius shelf area that extends no lower than 1,200 feet up to 4,000 feet above the airport elevation.
My read is that a 10nm or 11.5 statue mile radius is appropriate.
3-2-3. Class B Airspace
a. Definition. Generally, that airspace from the surface to 10,000 feet MSL surrounding the nation's busiest airports in terms of IFR operations or passenger enplanements. The configuration of each Class B airspace area is individually tailored and consists of a surface area and two or more layers (some Class B airspace areas resemble upside-down wedding cakes), and is designed to contain all published instrument procedures once an aircraft enters the airspace. An ATC clearance is required for all aircraft to operate in the area, and all aircraft that are so cleared receive separation services within the airspace. The cloud clearance requirement for VFR operations is "clear of clouds."
So in this case, we need to look at the charts, but the San Fran Area chart indicates a 20nm contact for NORCAL (Class B)approach.
The Tower is typically Class D airspace:
3-2-5. Class D Airspace
a. Definition. Generally, that airspace from the surface to 2,500 feet above the airport elevation (charted in MSL) surrounding those airports that have an operational control tower. The configuration of each Class D airspace area is individually tailored and when instrument procedures are published, the airspace will normally be designed to contain the procedures.
For SFO, I got this Instrument Approach Procedure from the main SFO page on airnav:
http://204.108.4.16/d-tpp/1010/00375IL19L.PDF
...note it shows a 15nm radius.
If we go to an IAP for SMF, we have a smaller airport and a smaller tower control radius:
http://204.108.4.16/d-tpp/1010/05490IL34L.PDF
So my point here is that we can get the information we need to define the official diameter of the geotag. Why would we want to geotag the radius smaller than the defined maximums?
