Proscan 2 Radios on 1 Computer
nyair1
I was wondering if its possible to set up 2 seperate icons on my computer for my 2 radios that i am using proscan on?? I have a 780xlt bearcat that has been running on it with no problems. I have started to use my bct15x now on the same computer. Is it possible to set-up 2 icons so that each one will save the info settings without having to open up two seperate ones and change the scanner settings all the time?? Thanks
egulleyjr
Banned
Unless the program has that capability, then the answer is no. HOWEVER, you might want to see if you can run TWO instances of the program at one time.
smason
Alberta Canada, Eh!
Yes. Make a copy of your Proscan folder, call it something like c:\program files\proscan2 and have one icon point to it, and the other to the original.
Easy Peasy.
