Apologies if the solution is obvious, but I need some help. I have spent some days revisiting links, faqs, and searching for how to simply run a dual feed with my already approved and up and running Broadcastify account I've had for over a month up on one scanner: Uniden BCD536HP
I am now wanting to run my feed utilizing two different scanners: Uniden SDS200 & BCT15X so as I will be letting the 200 send the digital stations out and the 15X handle the analog portion.
I am hung up on how to connect both said scanners to "Broadcastify" at the same time and my provided login and 3rd party [Advanced details] where you obtain the server, MOUNT, and password, ect...
I am a licensed user of ProScan. Both scanners have their own instance (separate) folder of ProScan config-ed and running per scanner successfully. Have tried different connections regarding the (Stereo Audio) L & R via each scanner using Line In with a Y cord. OR Line In and Mic In to successfully set-up the Audio portion, although, since I can't get both "Live" due to an issue I can't seem to find the solution to, cannot further test what Audio IN combination is best desired.
The issue is after I run my first instance of ProScan and connect to Broadcastify via "Source Client" with my credentials, the 2nd instance fails to connect with my credentials at the (Mount point in use) issue.
Have written to Broadcastify support and received a response with a couple of links that seems I have already read over and something of confusion to me where it is mentioned 2 accounts are needed for a dual (Stereo) feed, yet the support agent said that is not necessary.
Please help!
See Screenshots: The BCT15X instance of ProScan is up and running fine with live feed successful and the Sds200 instance of ProScan fails to get a connection to Broadcastify due to the mentioned error response as seen.
Please help!
