Proscan and SDS200
XPS720
Windham County, Connecticut
Not sure why but for the first time I see error --Proscan not able to locate color log for SDS200. I now see all blue instead of color. How do I fix the log file missing?
Thank you,
ProScan
Software Provider
Ontario, Calif.
Thank you,
Go to the Options Scanner Specific tab. Near the bottom are the options. Insure the "Display Color Mode" options is set to use Sentinel colors.
Also click the button "Sentinel profile.cfg File Location" then select the folder containing the Sentinel profile.cfg file. If not sure where the file is located then go into Sentinel menu Tools -> Options.
