PROSCAN AUDIO FEED QUESTION
KD9BVF
Janesville WI
I am trying to do a proscan audio feed at a remote site that only has ATT cellular hotspot for a connection
As ATT does not allow port forwarding thru the cellular system I was wondering if anyone else has ever ran in to this
and found a solution
Dave
KD9BVF
eaf1956
Evansville, IN
Are you setting the scanner up at that location or trying to listen at that location?
Sent from my SM-N960U using Tapatalk
brad2388
Climax, NC
you can run a vpn. i use airvpn thru my router using att lte data. or you can check out ngrok. its a reverse ssh method.
KD9BVF
Janesville WI
Thanks for the replies i have a scanner a remote site and want to listen to it from my home site (and control if possible)
i will look in to airvpn and ngrok never heard of either one
brad2388
Climax, NC
You wont need to port forward if you send it to broadcastify first.
Im doing just that thru att lte also.
