Proscan automatically changing frequency
lethalyoyo
Ive been running proscan for about two month flawlessly but today it has decided to change my frequency automatically. Ive tried different cables and same thing if i press down on the knob for volume when I receive a signal it’ll turn it down or up. But if i urn off proscan it’ll scan normal. Please help.
SDS100
bmaxmini PC
ProScan
Software Provider
Ontario, Calif.
The Resume Scan/Search function is set. Turn it off. It's located in the upper right corner. If you don't see it, click the little box until you see it.
Did you turn it on at some point?
lethalyoyo
The Resume Scan/Search function is set. Turn it off. It's located in the upper right corner. If you don't see, click the little box until you see it.
Well that was easy. Yes I did I’ve been playing with the program as much as I can. Thank you for your fast response. I’m sure my wife will be thrilled I’m back up and scanning 😂
